weld sequence id
weld sequence id
weld sequence id
      when welds are created in assembly using pro/welding , a weld sequence ID is assigned to each of the weld. This number is shown in the tail of each weld in drawing. can this number be removed or hidden in the drawing?
thanks,
ray.
