Diaphragm Question
Diaphragm Question
I have a building with precast concrete walls with metal deck (untopped) roof diaphragm. I have calculated to be flexible.
My questions is that the discussion in the code of rigid/flexible and whether to include torsional effects only appears in the seismic parts of the code. For wind design, can you always consider the diaphragm flexible, and only perform a tributary beam loading analysis to find loads to the shearwalls? And if so, can this be done for the wind loads, even if it would be considered rigid for seismic?
RE: Diaphragm Question
Additionally, ASCE 7 requires the torsional wind load checks (I believe this comes from quartering winds).
