NOx Emissions From Large Stationary Engine
Have measured NOx emissions from engine exhaust but analyzer units are in PPM. Need to convert to g/Bhp-Hr. Seeking formula for units conversion. Thank you!!!
RE: NOx Emissions From Large Stationary Engine
First: you need to know the NO/NO2 ratios of your NOx. Then also realize that EPA assumes all the NO goes to NO2 in the atmosphere. E.g. if you produce NOx with 90% NO, you will be "credited" with .1 * x + .9 * (46/30) x, or 1.48 g NOx emissions per 1.0 g NOx measured.
So - you measure 100 g NOx, convert to 148 g NOx equivalent, and then you have to know how many hp-hr were used in generating that much NOx.
e.g. - let's say your engine runs 23,000 g/min exhaust flow at 200 hp, and you measure 200 ppm (weight) NOx; your g/hp-hr is: 23,000 * 60 * (200/1,000,000) * 1.48 / 200 = 2.04 g/hp-hr
multiply the above by mass flow rate of exhaust (lb exh /hr) to get lb NOx per unit time (lb/hr)
divide by the corresponding horsepower to get brake-specific NOx emissions per unit time (lb/hp.hr)
in the end you'll get an answer that says 10ppm is about 0.03 gm/bhp.hr, depending on the above
