Creating annotation using UFUNC
I wrote following code to add add Annotation in drafting using ufunc, but when I call the dll file in unigraphics, it is not creating annotation.
#include <stdio.h>
#include <uf.h>
#include <uf_drf.h>
#include <uf_defs.h>
#include <string.h>
void ufusr(char *param, int *retcode, int paramLen)
tag_t note_obj;
  int orient1=0;
  static double origin1[3]={10.0,10.0,0.0};
  char st[2][50];
  UF_DRF_object_t object;
  UF_initialize();
  UF_DRF_init_object_structure(&object);
  object.object_tag=note_obj;
  strcpy(st[0], "a");
  strcpy(st[1], "b");
   UF_DRF_create_note(2,st,origin1,orient1,&note_obj);
   UF_terminate();
Any ideas?
RE: Creating annotation using UFUNC
Sorry, I posted the wrong one. Please read the code as below
#include <stdio.h>
#include <uf.h>
#include <uf_drf.h>
#include <string.h>
tag_t note_obj;
  int orient1=0;
  char st[2][50];
  UF_initialize();
  strcpy(st[0], "a");
  strcpy(st[1], "b");
   UF_terminate();
It works :)
Please copy only inside code;
If String is know you can use
st[0] = "a"; instead
st[0] = new char [100];
strcpy(st[0], "a");
void test(void)
tag_t note_obj;
  int orient1=0;
  char *st[2] ;
  st[1] = new char [100];
  UF_initialize();
  strcpy(st[0], "a");
  strcpy(st[1], "b");
   if( st[0] ) delete st[0];
   if( st[1] ) delete st[1];
   UF_terminate();
Thanku Siwy,
          st[0] = "a"; worked fine!!
I have one more question,
I have created a dialog, called Dialog1.dlg and in the Dialog1_Apply_cb function I am adding a point contructor function (to get the point location from the user). For that I am using any one of the following commands
1)UF_UI_point_construct ("Enter point",&base_method,&point_tag,base_pt,&response);
or
2)uc1615 ("Enter location", base_pt );
or
3)uc1616 ("Enter location",&ia2,ip3,base_pt);
and the variables are declared as follows :
UF_STYLER_item_value_type_t data;
UF_UI_POINT_base_method_t base_method;
tag_t point_tag;
int orient1=0,response,ia2,ip3=0;
static double base_pt[3];
When I call .dll file, the above mentioned functions are not popping up the dialog boxes.
I checked the returned vales from uc1615 and uc1616, both returned 8. The value 8 means  "Disallowed state, unable to bring up dialog"
The function UF_UI_point_construct returned the value 119001
What might be wrong?
Note that the above 3 functions worked fine in other files but not in the callback function that I have mentioned.
