Help with laser cutting conditions
I was just wondering if anyone could help me out with some laser cutting conditions.
I am running a 1500watt 6 axis laser.
Rotary chuck is being used for tube cutting.
Material: 4"dia 0.068 wall aluminized tube.
Thank you in advance.
RE: Help with laser cutting conditions
1500 watts - 500 freq - 100 duty - gas pressure should be around 10.
I'd suggest a fee rate of 105 IPM for a start and see where that leads you. As I'm not sure exactly what problems your having it is rather hard to know what to tell you.
Good luck.
if i can help you, let me know. i am curently running a SG
2000w, fanuc control. i know that when cuuting tube the focus point is critical.
