Dimarc
Dimarc
Hi all,
My problem is in Acad 2007 that the angular dimension
doesn´t work properly. The dimension lenght is paralel
to the object, but is shorter (osnap points are ok). And I don´t need a halfcircle before the value.
How is it possible to solve this problem?
Thanks a lot,
Robert
Thanks a lot,
Robert
RE: Dimarc
I do not understand the first problem. Can you attach a screenshot?
2nd: DIMARCSYM
Lothar
ADT 2004
RE: Dimarc
here it is.
The 2nd problem is solved, thanks.
Robert
RE: Dimarc
RE: Dimarc
The dim of the angle is right...
L.
ADT 2004
RE: Dimarc
If I am using a _dimangular it is possible
to draw continous dimensions, without interruption.
In case of _dimarc the ending of continous dimensions
are not on the same place as in case of _dimangular.
On the picture, the first dim line is with _dimangular,
the second with _dimarc.
I wold like to create a dimension style which looks like
_dimangular, but the value is the line lenght, not an angle.
Thanks a lot,
Robert
RE: Dimarc
(DEFUN C:DV2 (/ p1 p2 p3 p4 om ang rad arc ark) ; Dimension verts / along any circle
(SetVar "CMDECHO" 0)
(Setq om (GetVar "OSMODE"))
(COMMAND "Osnap" "END")
(setq p1 (getpoint "\nSnap to first point (must be on the arc also): "))
(setq p2 (getpoint "\nSnap to second point (does not have to be on the arc): "))
(COMMAND "Osnap" "CEN")
(setq p4 (getpoint "\nPick a point on the connecting arc: "))
(COMMAND "Osnap" "NON")
(setq p3 (getpoint "\nPoint to dimension location: ")
ang ( - (angle p4 p1) (angle p4 p2))
rad ( distance p4 p1)
arc ( abs (* rad ang ))
ark (rtos arc)
(COMMAND "DIM1" "ANG" "" P4 P1 P2 P3 ARK P3)
(COMMAND "DIM1" "HOM" "L" "")
(COMMAND "DIM1" "TE" "L" PAUSE)
(SetVar "OSMODE" om)
(princ)
After making the dimensions, draw a circle and use Perpendicular Osnap to put all the dimension arcs on the same radius.
