Dry Coolers and condensers capacity
Hallo to everybody !
I have realized a research but I have not found anything useful about following issue in the previous posts.
Therefore, I would be grateful if somebody could help me:
For the condensers you can generally give the capacity in a standard condition and then you can analyze the variation of capacity in different conditions with a linear variation of TD, as a rule of thumb.
That’s the reason why you give the heat rejection. Ex, if with a TD of 20K you have got a certain capacity, with a TD of 15K you’d have a capacity near 75% of previous one.
Please, I’d like to know if there the same rule is suitable for the dry coolers ?
If not, is there any rule to calculate the capacity of chillers ?
Thanks in advance !
Thanks in advance !
RE: Dry Coolers and condensers capacity
For dry coolers I mean water coolers.
When I ask : do you know a method to calculate capacity of these water coolers, I forgot to specify: "In a condition different than a specified one"
Sorry for not being clear !
I don't believe they would let you use data from one set of conditions and extrapolate to another. It would have to be actual performance data.
