Chaining Lines In Model Space??
I need to select multiple lines...Is there a chain command that will select all the lines that are linked together?? i.e. In UniGraphics... Chain > Select Line > End Chain and all lines are selected. Anyone know anything about that?? Thank you in advance
Ryan Hill
Design Engineer
bestCADsolutions, Inc.
RE: Chaining Lines In Model Space??
a
In a sketch, right click - under '*.* object' - select 'auto search'
chaining must not only be able to be done in sketch mode. Isn't there a way to do it in regular model of drafting space??
Ryan Hill
Design Engineer
Try 'Distance Propogation' within the 'Join' function.
hmm, not seeing that option anywhere within the join function. I am using V5R17 if it makes a difference.
Ryan Hill
Design Engineer
Ryan,
pick the 1st segment, hit Join, right-click in the "Elements to Join" field and select "Distance Propagation". If it fails, increase the default 0.001 mm merging distance to a convenient value.
Best regards,
Stely
ok, wow. They sure don't make it too easy in Catia. Thanks alot.
Ryan Hill
Design Engineer
Uhh, sorry, nother question on same subject. I notice this works in model space, but there is no join command in drafting. When I do this in model space and I make my chained line dashed, how do I get the dashed lines to come through on my drawing view?? When I bring in the view, they just come in as solid lines...Thanks again.
Ryan Hill
Design Engineer
So is there a way to bring dashed lines through to the drawing?? Or is there a way to chain lines in drafting? thanks
Ryan Hill
Design Engineer
