Movement Joints - Internal Masonry Panels
I think I already know the answer but:
We have internal masonry walls between concrete columns. The columns are at 7.5-8m centres. We will need to provide vertical movement joints at 6m centres.
Can we design the masonry panel for flexure taking the masonry on the others side of the movement joint as a pined restraint (therefore panel is pinned on four sides) or do we have to rely on the restrain at the head, foot and other side of the wall only (panel pinned supported on two horizontal sides and one vertical side)?
Silly question it obviously the second case?
Chris
Chris
RE: Movement Joints - Internal Masonry Panels
