NX4 post simulation
NX4 post simulation
NX4 post simulation
When using NX4 with NX Nastran and reviewing the post process results, does anyone know how to tone down the images? For example, if a result says the displacement is 4.56e-004mm but the images appear to be deformed much more than that. I guess I would like the image to be representative of the deformation value and remove anything that appears to be over exaggerated. I've searched through the utilities but could not find anything...any help?
RE: NX4 post simulation
Hi
Since you mention NX i guess you work with Femap.
Then you can try View Options - Postprocessing - Deformed Style. There you will find some options to try.
Good Luck
Thomas
