L-G fault in 3-ph system
In a 3-ph system with neutral not solidly grounded, why the phase voltage of unfaulted lines gets increased 1.732 times its nominal voltage in the event of a L-G fault.
Mathematically, it is clear but what actually is happening in reality?
RE: L-G fault in 3-ph system
You can look at:
http://www.i-gard.com/appguides.htm
lots of good info, in the beginning of the application guide named "ground fault protection on ungrounded and HRG system", they explain that
Marmite
The phase voltage DOES NOT get increased.
The voltage to ground from the two unfaulted phases increases.
Bill
"Why not the best?"
Jimmy Carter
In fact with certain earth fault resistance one of the two healthy phase-to-earth voltages will rise up to sqrt(3) + 5.2 % => 1.82 Un.
This maximum happens, when the fault resistance is about 37 % of the total ground reactance Xcap of the network.
"In fact with certain earth fault resistance one of the two healthy phase-to-earth voltages will rise up to sqrt(3) + 5.2 % => 1.82 Un.
This maximum happens, when the fault resistance is about 37 % of the total ground reactance Xcap of the network".
It's really new for me. Ransor, I assume is same for Petersen coil system. Tanks a lot for information, it's probably explained me several cases.
Best Regards.
Slava
