direct shear test - standard loading
Hey there - I'm looking for some general information regarding direct shear tests. When these tests are performed, is there a specified/typical load that is applied to the specimens and what is the standard/typical area of specimen?
I have some values obtained from a direct shear test performed in another country and I am trying to determine if they used similar values.
Also, is there an ASTM standard for these tests?
Thanks in advance!
Thanks in advance!
RE: direct shear test - standard loading
