relationed part in asemblies
i' m learning SE v19. i've created a simple shaft (part1 protrusion) and inserted it in an assembly. Now i'm trying to create another part (part2) at the end of part1, within the assembly (using create in place), and i want part2 to move as i will change the part1 protrusion lenght...
i've tried "by graphic input" option.. didn't work
i've tried "offset by assembly by keypoint" didn't work
i've used the "include" command for my frofile...the profile changes as i change the part1 dimension but his position doesn't change...
how can i do this?
Thx
how can i do this?
Thx
RE: relationed part in asemblies
As part 1 moves you want part 2 to follow it.
What assembly constraints are you using. If you have a face in part 2 constrained to a face in part 1, normal to direction of travel, it should work.
When in Edit mode, modifying a part, you may not see the changes flow up to the assy. I can't remember if there's a setting to change this.
However when you return to the assy, it should have moved.
KENAT, probably the least qualified checker you'll ever meet...
use ALT+U that should update
But when usind 'Create in Place' before starting your
Profile use MainToolBar --> Insert --> Interpart Copy
and select a face from Part1. On That face you may then
draw your profile as usual. Now it should stick to that
face.
Also take note: a part that is created in place will
have a 'Grounded' relation applied to it by default.
dy
downside of the method with 'Interpart copy' is that the
part is associated with the asm and a failing Interpart
connection is hard to repair
Another approach is:
- open a new part
- Insert part1 as Construction
- now design part 2
Back in assembly insert and constrain Part2 as usual. Downside
Part2 depends on Part1.
or do just what you've done before but without interpart copy
when your part2 is finished.
- delete the 'Ground' Relationship
- constrain Part2 to Part1 the usual way
When no inclusions made from Part1's geometry Part2 is totally
independend (I think that was the intention Part2 should just
follow Part1)
dy
the only constraint that i have is the one when i created the part2 ;"by graphic input"
DONYONG
The ALT_U (update all links) option didn't work either.
The "inter-part copy" option worked fine but i still have imported a face from part1 that i don't really need...exept that i use this new face to start a new profile on. And this way the part2 moves as i change the lengh of protrusion of part1...besides the fact that i have an extra suface that i don't need..it's ok...but there must be a way to do so without importing that surface...
another quick one.... is there a way to smart-dim a line from the perimeter of a circle? without adding a point.... or does tangent/offset exist?
As for your quick one, I'll assume you're in the sketcher. Dimension to the line first then to the circle. May need to change dimensions from horizontal vertical, maybe play around with intellisketch.
Out of interest, have you done the tutorials?
yes, design your part by 'Create in Place' just as you
would do without the assembly.
Upon 'Return' delete the Ground RelationShip and position
your part by the available Relationships.
yes, check the SmartStep (RibbonBar) when SmartDim is active
dy
obviously not ...
dy
sorry to bother you with those questions!
See thread562-206155: SolidWorks to SolidEdge Relearning Curve & thread562-208631: Tips for robust sketches & FAQ562-1410: I'm having trouble with sketcher (SOLID EDGE ROBUST SKETCHING TIPS)?
For my 2C it is easy to learn, I learnt it without doing most of the tutorials, without training and with just help from a couple of users in my department.
It is different though, so if you're stuck trying to do things the same way as SW you may have trouble. If however you're willing to just think about what the end result is and how you can get there with SE you'll be happier.
thx everybody
i'll probably be back with some different problems later..
(I'm a bit rusty, hope I didn't buther your language too badly.)
(Wow if I can't manage my native tongue...)
Bienvenu dans le monde de Solid Edge! Un peu comme les autres ont dit, SE va être en mesure d'accomplir la majorité de ce que SW peut faire mais évidement il n'emprunte pas les mêmes méthodes. Soit attentif à la "ribbon bar" et n'hésite pas à poser tes questions sur ce site.
Patrick
However, this is off topic now, au revoir. (Pretty sure I got even that wrong)
Bonne chance sur Solid Edge.
Kenat, you actually got it correct. Pat's second sentence goes something like, «as the others said, SE can accomplish most of what SW does, but of course not through the same methods».
At work, since I was the one who signed the purchase order for 2 licences of SE, I ordered the French version. My collegue who's been assigned to this new software with me was not thrilled! Few companies here choose the french versions. I have to confess that for the technical field, French is not as efficient a language as English. For example, the "protrusion" tool in French SE translates to "ajout de matière par extrusion". Cutout is "enlèvement de matière par extrusion". 5 words for one... LOL.
You know, this is one thing SW has over SE: there's only one version, multilingual, of SW. You install English plus your choice of language, among 10 or so. Then, you can switch to English or the other language in the preferences menu. You just need to start the software again to apply the change.
Cheers
Patrick
