Solid Edge Properties List
I have seen mention of custom properties like
"SE_ASSEMBLEY_QUANTITY_OVERRIDE". This looks like its from a solidedge standard list or something. Is there a list or table some where that tells you to string the values SE and ASSEMBLEY AND QUANTITY AND OVERRIDE together for a desired effect. Where do i look for this stuff.
RE: Solid Edge Properties List
We've written BKMs for the ones we use most often.
thread562-210329: custom property gave how to set user defined Qty & units. It should be pretty easy to adapt this to not have units.
For AR items I have one too. I'm having a network problem right now or I'd post it.
KENAT, probably the least qualified checker you'll ever meet...
SE Help --> tab: Index --> key in: non-graphic parts
select item: creating --> double click on it and
select 'Create a Non-graphic Part That Uses Units and Value'
HTH
dy
--Scott
http://wertel.eng.pro
