SST Bolt Shear and Tension Values
I am designing a sst 5/8" bolt for shear and tension. Does anyone have the allow shear and tension values for the bolt?
T.
T.
RE: SST Bolt Shear and Tension Values
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
You have posted a number of questions about stainless design in the last few weeks that show no real clear understanding of how values are obtained for certain items. In this case it is a bolt. If you know your material properties (304,316, etc.) than you can obtain your shear and tension values for your bolt if you know the diameter. You list yourself as a Civil/Geotech. guy. Maybe you should have a structural guy look at this for you. Just my 2 cents and take it as a grain of salt, because we're all here to learn, but when something is beyond our own capability we must be able to recognize that.
FeSE,
I'm guessing he means stainless steel. But he does not list the grade or anything of the sort.
RC
All that is necessary for the triumph of evil is that good men do nothing.
Edmund Burke
I presume you are using the common abbrev. for stainless.
If so the attached document may help.
Batman2
