Display Change
Display Change
Two questions:
(1) I'm making a revision to an older drawing and the vertical dimensions have the numerals displayed vertically. How do I get them to display horizontally.
(2) When I move my cursor into a view, aqua blue squares appear showing the constraints/relations of various entities. How can I turn this function off?
Thank you for your time!
Matthew
Matthew
RE: Display Change
http://www.EsoxRepublic.com-SolidWorks API VB programming help
RE: Display Change
RE: Display Change
Regarding item 2, under View > Sketch Relations should be toggled off to hide those little squares.
Reaper.
