UL style cables question
I would like to ask you which parameters are given by UL XXX marking in the case of UL style cables. I am from overseas and it is not 100% for me the system of this marking.
For example for UL 1015 style cable I can tell from my limited resources that it is manufactured in AWG 30 - 2000 MCM range, maximum voltage 600V, Max temperature 105C with 0.030 inch PVC insulation. Which additional parameters are given by this marking ( f.e. flexible service, core stranding, spark test, flammability test, etc. )?
Where could I find differences between varios types of UL style cables and its subcategories ( MTW, AWM .. )?
I would ask if somebody know if there are UL standards to smoke density and dark fumes emission during burning ( equivalents for EN 50268, IEC 61034 ).
Thank you for answers.
RE: UL style cables question
I know I tried it yesterday. Can you imagine, NO hit on UL 1015??
Keith Cress
If you are a UL customer that has active projects with them to obtain listings, you now get on line download access to all of their published standards.
http://www.ul.com/wire/faq.html
Bottom line is you need to look at the standard anyways (UL758 or others) or give a call to your local wire manufacturer whom Im sure would clarify for you.
http
David Baird
Sr Controls Designer
EET degree.
Journeyman Electrician.
