OPC Toolbox Block library
Hello to all,
I am trying to exchange some data between Simulink and Simatic PC station. Everything goes well untill I try to make model in Simulink because I can not find OPC Toolbox Block library in Simulink Library Browser. I have OPC toolbox and the connection to OPC server is OK. I am beginer so please tell me what did I do wrong?
RE: OPC Toolbox Block library
xnuke
"Live and act within the limit of your knowledge and keep expanding it to the limit of your life." Ayn Rand, Atlas Shrugged.
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
Yes, I tried that because I found in tutorials example where it is stated, but it says that it is undefined function or variable (see attachment).
Is it posssible that I skiped something during installation because I have all other libraries. Is it possible that you can export this library and send them to me somehow?
Thanks in advance.
I cannot send you software files. You'll have to use your installation discs. If that fails, I suggest you take up the problem with The Mathworks.
xnuke
I will try to reinstal Matlab/Simulink today. Probably it is the best solution.
Thank you
I reinstaled Matlab/Simulink. It is OK now...thanks for help.
