Power loss on MAN 6L40/45
I lose power/performance from a 6L 40/45 600rpm MAN engine. After T/C overhaul the engine runs at full performance for about 1500 - 2000 hrs and then drops off so the CPP pitch limit drops from 16.5 to 11-12 by about 4000 hrs. The limit is caused by exhaust temp limits of 480 deg C. The T/C is originally ABB VTR 354 but is now mostly pattern parts. Fuel is IFO 380. All scavenge air leaks have been cured as have exhaust leaks. Engine room temp is about 50C.
RE: Power loss on MAN 6L40/45
If individual cylinder sensors, is it always a high value (as opposed to mean deviation) and is it always the same cylinder?
Is it a single cylinder high temp? If so, always the same cylinder, or is there more than one high or can it be different cylinders at different times?
Single cylinder hi deviation from other cylinders?
High turbo inlet?
In my case, if turbo slows down and exhaust temps increased, I get a load reduce signal from the safety system. This can be from either (for instance)
1. cylinder #8 high temperature
2. cylinder #8 has a higher mean average temperature compared to the other cylinders.
For me, my power management system then derates that generator in either case. For you it adjusts CPP I assume. But either way, the limitation is caused by one scenario or the other (or something similar), and for me identifiable to a single cylinder, unless it is turbo inlet temp. So if your safety system works similarly, you should know exactly what is causing the load reduction. But of course that is only a start in defining your problem.
Maybe the only real help I can give you is to suggest a users group. There are users groups for almost all MAN models. I got hooked up with the users group for our model by calling MAN Germany, and after only a surprisingly few transfers, I was given the contact of a person in a users group for our model. That is where I believe you will get really specific help.
Being electrical, I start my focus on the sensors, which is why I have been trying to drill down on what specific sensor is initiating the action.
You have a problem with the air supply to your engine. Try waterwashing your T/c with a mix 50%water, 25% detergent (TEEPOL) 25%light diesel or kerosene. A couple of pints is sufficient. ENSURE you give the mix a good stirring before feeding in the air intake filter. This will also clean the air side of your intercooler.
Read off your charge air supply before and after, you will see a big change. Also check the stack exhaust, smoky before and clear afterward.
Offshore Engineering&Design
The temp rises are common to all cylinders, not just one and sensors are checked regularly as errors normally show up as extreme, and impossible, fluctuations.
The air supply is very possible. The T/C's are washed every 6 days with an impulse system which puts water in for 6 seconds every 6 mins and the whole process takes 36 mins.
Will talk to my Superintendent about washing with the mixture suggested.
This mix was recommended to me many years ago by the Brown Boveri mechanics. It is a lot cheaper than the proprietary chemicals and more effective. The reason I emphasised giving the mix a good stir just before use, is because the light diesel will separate out to the top if left standing and will 'pop'your safeties. Lesson learned because of a bone idle Motorman.
Waterwashing sometimes can not shift the oily dirt build-up on your T/C air side blades and after cooler.
