Machining thick Aluminium
Does thick aluminium plate have any " locked in stresses"
From a disc 30" dia and 5" thick we wish to make a saucer to very precise curvature. If we machine the concave face first to exact curvature will there be any changes when we remove a lot of metal from the other face? Its only the concave side that critical so maybe we machine this side last and then it will be as per planned curve, but it would be a lot easier to have done it first. Hope someone can advise.
Regards CM
Regards CM
RE: Machining thick Aluminium
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
Even though this procedure is for Cryo mirrors I've seen very similar procedure for terrestrial mirrors.
http://www.techbriefs.com/content/view/479/32/
I'm not sure what you mean by "very precise." Are you talking 1/4-wave, 1/20-wave? You might need to interferometrically check the surface at each step of the process to ensure that the previous processing hasn't changed the surface figure.
TTFN
