JPG not supported in drawings?
how come i still cant insert JPG images into the drawing sheets?
RE: JPG not supported in drawings?
I was able to do it.
What version are you using and what steps to insert the picture?
Chris
SolidWorks/PDMWorks 08 2.0
AutoCAD 06/08
ctopher's home (updated 10-07-07)
Have you tried ... Insert > Picture?
BTW using a JPEG in SolidWorks or Word or PowerPoint is not considered to be a good practice, since most Windows programs do not support the lossy compression and actually uncompress the JPEG into a bitmap. This is why inserting a JPEG makes the file very large and many times affects performance. You may want to use GIF or TIF instead.
Open the image in an OLE compliant viewer (XnView, IrfanVIew, Paint, etc) first, then copy and paste from there.
cheers
BMP works apparently.  JPG comes in as a link.
I am doing insert->object and then picking the image file.
I am on 2008/PDM SP2.1
I would suggest converting the jpg to a bmp anyway, because the jpg compress method isn't supported by many programs, so it ends up being the same size in the filesize as an uncompressed format, just with more work for the software. :)
Matt Lorono
CAD Engineer/ECN Analyst
Silicon Valley, CA
Lorono's SolidWorks Resources
Co-moderator of Solidworks Yahoo! Group
and Mechnical.Engineering Yahoo! Group
