how to construct arc
Hi all,
I wanna construct arc (just like in the picture) and the revolve it to be a shallow dome.
Is there any other way to do this than using LINE=P ?
thanks in advance
kaninchen
RE: how to construct arc
Your attached file is a .cdr file - is this a Corel Draw file?  Might be better to attach an image (.jpg, .png).
However, if you are creating geometry, do you not have access to ABAQUS/CAE?
Martin Stokes CEng MIMechE
Your only choices are line=p for a parabola or line=c for a circular arc for *NFILL.
If you can describe the profile with a set of equations, then you could use parameters to create the nodes.
