Mixing electrolyte during charging to reduce charge time
Here is one more problematic I would like to get more info or some opinions.
I have heard that with mixing up the electrolyte during charging the charge time can be reduced with up to 30% and this mixing is carried out in big battery station by air.
I read somewhere that the mixing up of the electrolyte could be provoked electrycally by applying short negative voltage pulses during charging.
What is your opinion - it might be true or it is rather a myth and it case it would work if it will reduce the life cycle of the battery by applying these pulses ( effectively changing polarity ) for a short time?
I have not found other source to verify this method and my own electrochemistry knowledge is limited to make directly the consequence.
RE: Mixing electrolyte during charging to reduce charge time
However, I would caution against trying to "speed up" the charging process, as that might cause uneven restoration of the plates, resulting in an overall lower reliability.
TTFN
