Halogen bulbs 12vdc vs. 12vac
I have a halogen bulb that is normally used with a small 12vac transformer. I can also light this bulb straight off a car battery that's 12vdc (the battery of course runs down very quickly). My question is, "Do I harm the bulb by using 12vdc on it, since it's primarily used with that 12vac transformer?" And "Are there halogens that are made specifically for 12vdc applications"? Thanks
RE: Halogen bulbs 12vdc vs. 12vac
Yes, there are halogen bulbs designed for DC use. Usually they are ruggedized, assuming that the user will be using them in a vechicle which will shake them around.
The wattage rating of the bulb will determine how fast your battery runs down.
Lewis
Second question: there are different kinds of 12 V halogen bulb depending on its us (car or home applications) rater than on current type. That differences mainly affect to mechanical arrangements.
Julian
