How to change the moving direct of Screw Joint Kinematics
Hello, I need your help to solve the problem. I am using Screw Joint Kinematics to simulate a part moving in a Helix curve. The simulation is good except the moving direction is not I want. Quetion is how to change the moving direction from Left hand to right hand movement.
I appreciate your urgent assistance.
Greetings
Greetings
RE: How to change the moving direct of Screw Joint Kinematics
Change the pitch for a negative value...
