Shield protection on hot lines
Where can I find photos, suppliers, and specifications of shield protection of hot lines for personal protection where insulation is not required for energy savings.
regards,
roker
regards,
roker
RE: Shield protection on hot lines
cheers,
gr2vessels
Steve Jones
http://www.pdo.co.om/pdoweb/
The screen is set off from the pipe/wall and provides an air gap between the hot surface and the personnel. Sometimes necessary where heat losses are desirable (for process reasons) or because if you insulate the surface(metal) it will melt! (Think smelter/molten metal equipment)
