WorkOver Identification
Guys can you please help me out with a good book on work over identification. For example how to look for an acid job, Frac Job or how to identify weather to use plunger lift, gas lift, intermittent gas lift, velocity strings etc. how would you differentiate which one to use. I have a good idea how to design these but the identification using the production or test seperator data for onshore wells. Can you guys reccoment any good SPE papers or a good book that shows you how to identify workovers for gas condensate wells or oil wells. Any input would be appreciated. Thanx
RE: WorkOver Identification
Which kind of intervention or artificial lift is the best intervention or artificial lift for the well? - No, I don't know any book written simply to answer these questions. The reasons are many and are related with economics, equipment availability, expertise, formations fluid and well characteristics. Each of these components are treated in different books, or some of them together in Petroleum Handbooks, BUT none of them gives you a ready to go recipe of what WO is best for your well.
Tim
