How to select blocks that are touching lines
Lets say I have bunch of lines and bunch of square blocks.  Is there a way to (script or command) select all the blocks that are touching the lines?  It is simmilar to fence command but I want to define the fence lines with the lines that are drawn already.
Never, but never question engineer's judgement
RE: How to select blocks that are touching lines
You may want to try the command GROUP and select all the objects that you want to pick as a bunch under that command.  When you have a screen full of objects whereby selection is difficult, invoke the group command  and the assigned group name to modify that selection.
