Corrosion rated of uncoated steel
Can anyone provide generally accepted anticipated rates of corrosion for uncoated steel exposed to the elements? I realize the rates of corrosion will vary based on a myriad of environmental criteria, but are there some basic ranges of corrosion rates that can be provided?
Tim
Tim
RE: Corrosion rated of uncoated steel
In more corrosive environments rates extend to 0.012in/yr.
You can find this information in many FHWA or NCHRP references.
![[pipe] pipe](https://www.tipmaster.com/images/pipe.gif)
Qshake
Eng-Tips Forums:Real Solutions for Real Problems Really Quick.
