Dragging Blocks
Dragging Blocks
Dragging Blocks
When I drag blocks and objects between two windows sometimes the object/block goes down to a scale of 25.4 i.e. between feet and mm.  I use mm (millimetres).  Does anyone know how to fix this without using scale up in the new drawing ?
Thanks !
Three cheers for autocad !!!
RE: Dragging Blocks
INSUNITS
INSUNITSDEFSOURCE
INSUNITSDEFTARGET
ADT 2004
RE: Dragging Blocks
Can anyone explain a bit better please?
