damping factor calculation
Hello, i'm tryng to calculate the damping factor and damping ratio from some data i gathered. I have plotted the results so i'm trying to use the logarithmic decreament method.
I have measured the amplitudes, so i have Xn and Xn+m, but i keep getting -ve results, and i'm sure thats not right. Surely i should be getting a value lower than 1 as the data clearly shows the system to be under damped.
Any thoughts on where i'm going wrong?
Cheers
RE: damping factor calculation
sounds like you have found the log "increment" (the inverse)- but i agree not much of a description
