DIN Schedule Charts
DIN Schedule Charts
DIN Schedule Charts
  Where might I find charts for DIN pipes so that I have the correct wall thickness' pertaining to the proper material?
RE: DIN Schedule Charts
Check the following standards which can be purchased at www.beuth.de
DIN 2448 Seamless Steel Pipes and Tubes; Dimensions, Conventional Masses per Unit Length
DIN EN ISO 1127
Stainless steel tubes - Dimensions, tolerances and conventional masses per unit length (ISO 1127:1992); German version EN ISO 1127:1996
ISO 2037 Stainless steel tubes for the food industry
DIN standards for butt welding fittings:
DIN 2605 part 1 & 2
DIN 2615 part 1 & 2
DIN 2616 part 1 & 2
DIN 2617
Note:
1. Fittings from part 1 are weaker than a pipe of corresponding wallthickness
2. Stainless steel fittings may be difficult to obtain with wallthicknesses to those standards. Typically only specific thicknesses are available which does not always match the fitting standards.
regards
Mogens
