Piping Cost Data, Caribbean
I have to cost out the piping system for a constuction project located in the Caribbean.
Is anyone aware of Mechanical Cost Data adjusting factors for construction sites in the caribbean, in particular, Anguilla Island?
I have the 2003 RSMeans Mechanical Cost Data Manual.
Any thougts?
--Steve M.
Any thougts?
--Steve M.
RE: Piping Cost Data, Caribbean
Is the cost estimate including all material or installation only? Also, what is the purpose of the estimate - is it for a competitive bid or for a client to look at alternatives? Have you been given direction on the estimate as far as accuracy?
Greg Lamberson, BS, MBA
Consultant - Upstream Energy
Website: www.oil-gas-consulting.com
What I would do is take widla's information and also check a few material costs & compare them to your 2003 cost data and that should give you an idea of how to escalate it. I would look at materials and labor separately and not try and come up with a single factor. Local labor rates can be compared to what is in Means for a labor factor.
Then use your Means to come up with a cost and use your factors to get to a rough 2008 estimate. I would also docuement the estimate assumptions.
