Structural glass design code?
Is there an American structural glass design code or manual. I've tried to to Google this without much luck.
I am trying to provide calcs for a glass canopy, and need some design parameters and allowable physical properties. The canopy is supporting its own weight, snow load, and wind; and must span between supports. Thanks in advance.
RE: Structural glass design code?
GANA Glazing Manual should be given what you want.
I believe IBC2003 has some basic glass thickness and plate lengths vs load tables.  See Chapter 24
The IBC charts are the best way to go.
