AutoRoute Express
AutoRoute Express
I would like advise with using a old based dos version of autoroute with win98se. It appears to work but requires to switch out to a dos window, This some times works ok then others it will freeze the system. The to recover it requires a reboot I have tried various graphic drivers. The reason for using the old version is it does mulitple costing for vehicles. its used for a courier costing system for quick quotes. I used to use 486 machines but have just up dated to AMD 1.4Ghz with nvidia graphics cards 256mb memory
