calculating joint slippage
Does anybody know of any references for calculating the deflection of timber truss split ring connections.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: calculating joint slippage
Do you know if there is truly slip in these things?
http://bo
www.SlideRuleEra.net![[idea] idea](https://www.tipmaster.com/images/idea.gif)
Are those values in meters? It's pretty small. If so, then the split rings don't move much...
http://www.slideruleera.net/miscellaneous.html
