Geopak Survey Won't Show Ascii Point Description When Imported
I have an ascii file that contains north and east point coordinates with a descritption using commas as the delimiter. I use Geopak Survey to import the points on screen and the points show up, but the description that indentifes the points are not shown on the screen, how can I get geopak to show the description that is inside the ascii file on the screen with the points?
I have checked all the options in the survey mapping perferences dialog window to show all the elements (such as points, descripiton, feature, etc.), but I still don't see the description labeled any where on the screen with the imported points...why, and how can I fix this issue?
The same question has been posted on the Bentley Geopak's Discussion Board, but no one was able to answer the question, or at lease I had not found an answer yet.
Please Help If You Can,
Thanks So Much.
