How to Calculate Thrust From a Ducted Fan
hi
can anyone tell me how much power you will need to produce 2000lbs of thrust from 70 inch blades in a ducted fan?
also i take it there will be contra rotating blades to stop the whole setup from spinning?
any help and advice will be appreciated
thanks
RE: How to Calculate Thrust From a Ducted Fan
Use the search engine to try and find a previous discussion on this. If you can, post the thread number in this thread, read it and see if it answers your questions.
You need to know the figure of merit (say 0.5), and the motor power.
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
