convective flow
convective flow
I'm working on designing a natural circulation system. I'm hoping for some help.
I need some help determining flow rate based upon differential temperature and also calculating what pressures will exist at various points in the system.
Thanks a ton
Wes
Thanks a ton
Wes
RE: convective flow
http://web.mit.edu/lienhard/www/ahtt.html
TTFN
RE: convective flow
When I was clicking the link, i thought for sure i was going to some place where i could purchase the appropriate text - i was super excited when i saw that i could just download the thing!
Awesome help!
I'll be back though if i need some clarification!
Wes
RE: convective flow
I want to essentially have water/ethylene glycol mixture 30 ft x 10ft x .25 inch solar panel. I want to have a 25 or 30 ft high vertical pipe connected to it, where it would flow upwards into a heat exchanger and then through a fin fan heat exchanger such that all the solar energy that went into the fluid would be removed... then fluid would then fall into a pelton turbine. I want to play around with different sizes so that i can design a system around the pressure / flow requirements for the turbine.
If anybody has a simple way that i can approximate this and do some rough calculations without forcing me to break out my Ti-89 - that would be awesome. In the meantime, I will continue to go through this text and make my brain hurt by going through all the calculus (blech!)
Thanks again guys!
wes
RE: convective flow
TTFN
RE: convective flow
I want basically buy a stock water turbine, and they are going to ask me how much head to you have and how much flow? I'd like to be able to calculate that.
Thanks again!
Wes
RE: convective flow
Basically the issue with solar panels is that they are only 10 to 15 percent efficient. Whereas a water turbine is upwards of 70 percent and as long as i can minimize heat loss through insulation on the hot leg, I'm thinking i can get considerably more usable power out of a convective flow system.
RE: convective flow
As a starting point for your analysis, forget the heat exchange part. Assume one vertical leg of your loop is hot, one side is cold. Look up the densities at each temperture, use those temperatures to calculate a differential pressure from one side to the other. Use that pressure with a Moody chart or similar tube/pipe flow equations to calculate flow rate.
I think the problem is that for the amount of heat you put into the fluid, you get very little expansion, as compared to air, so it's hard to extract much energy back out of it. You're mainly just heating and cooling a fluid.
RE: convective flow
How would the difference in height affect the differential pressure?
density is usually in kg/m^3 or lb/ft^3
pressure is psi or metric equivalent
so, if the cold leg is something like 980 kg/m^3 and is at 25ft in the air and the hot leg is 900 kg/m^3 and is at 0 ft relative elevation...
so, you'd have 80 kg/m^3 of "relative differential density"
would you multiply that by 7.62 meters to get 609.6 kg/m^2
... or is that going down completely the wrong path?
I know there is precedent for this - US nuclear subs have an emergency cooling system that operates in this fashion and i know that the thermal capacity they are designed for is something around 7 percent of the thermal output of the reactor - which is pretty substantial.
So, i guess, where do i go from here?
Wes
RE: convective flow
They type of flow you are talking about is simply driven by the difference in density. The volume of water in the hot leg weighs less than the volume of water in the cold leg.
The density of water can be written as a function of temperature.
The rate of temperature change is a function of your solar collector's ability to make water hot. Assume that you can size the heat rejection to match.
This gives you everything you need to know to calculate the driving force and power input.
Opposing the driving force is pipe friction and the pressure drops through the collector, heat rejector and turbine. All of those pressure drops can be written a functions of flow.
Equate and solve for flow.
RE: convective flow
Thanks a bunch. BTW, I'm assuming that there is a general design guideline for sizing pipes vs. volumetric flow rate. In my scenario, I want to minimize head loss so, I would want to oversize everything to the extent practical from a cost standpoint as to minimize non-useful energy loss from the system (i.e. i want as much energy as possible available to spin my turbine.)
Wes
RE: convective flow
The point that you don't seem to have is that the energy you are removing from this system with a turbine is some of the energy required to get the fluid lifted back up 25 feet. Hot water doesn't rise on it's own, it has to have colder, denser water to force it up. You need to sit face-to-face with someone who can show you the equations involved in determining whether your proposed system could produce excess energy.
Another point that you may not have grasped is that in order to force the hot water up 25 feet, you will need to have cooler water flowing down. The heat transfer from your system may require long holding time, or a very large tank in order to realize a temperature differential.
Most of the help available on this site is for a very specific question about some aspect of a system, not how to design the whole system. If you think your idea is a money-maker you will need to hire an engineer, or visit the university.
RE: convective flow
Even at that, it's questionable whether that's any more efficient than a photovoltaic solar panel that converts to electricity to drive motors or pumps.
TTFN
RE: convective flow
Even in the apparent example of convection currents in water, almost all the energy is simply shuffling the water around, and much of that is lost in friction and the inevitable countercurrents. Very little of it can be extracted for mechanical advantage.
TTFN
RE: convective flow
Insofar as heat removal - i don't see that as an issue. I already have a use for the thermal energy that would be put into the system via the sun. The excess would get dumped to another thermal load or if its truly excess i would just dump it to the atmosphere via a fin fan HX, thus creating my falling column of water to push the hot water up.
RE: convective flow
RE: convective flow
However, it sounds like you now talking about heat pipes. Heat pipes are used to remove heat from lots of systems, but that's the extent of it; heat pipes are not used to generate mechanical energy.
TTFN
RE: convective flow
in that case
i'm sorry that i asked the question in the first place.
although, i really don't see where the big hang up is - i'd really rather have that explained to me rather telling me that i'm living in some kind of lala land. That is completely unhelpful.
cold water falls, pushes hot water up. Circulation is dependant upon temperature difference. Head is determined by temperature difference (therefore difference in density) and relative difference in elevation.
insofar as heat removal from a nuclear reactor. The primary system stays single phase. The secondary system undergoes a phase change. So, the point of how the heat is removed is moot isn't it?
Why can't a heat pipe system using natural circulation be used to spin a water turbine? I'm not talking about a huge turbine to power a quarter of a city, i'm talking about a water turbine that could provide a percentage of electricity for a single home. These turbines can operate with as little as 6 ft of head. That's not alot - a little over 2.6 psi.
let me restate or state if i haven't made myself clear before. I'm all for living in the real world, but, don't tell me that an idea is dillusional without backing it up with some kind of calculation or condition that would make the construction costs and difficulty so ridiculous as to render it impractical beyond any possible gains that it could offer (i.e. 500 ft tower, to power a turbine that would only produce 5 percent of a home's need).
On a second thought - what about having this convective loop to 2 phase instead of single phase. I don't think thermal energy input is a problem - it's just a question of sq. footage which can be built for cheap.
RE: convective flow
For someone on this site to go through all of the calculations and back and forth posting of discussion to develop or analyze your system is not a realistic expectation. If you can break your questions down to very specific ones (posted separately), then you might get more help.
RE: convective flow
Just one clarification:
In pressurized water nuclear reactors, a secondary side cycle is set-up where the steam removed from the steam generator drives a turbine-driven pump which feeds cold water to the steam generator. This, along with the design of the generator and piping, provides the heat differential needed to move water through the primary side. Without the secondary side loop there would not be natural circulation.
BTW, my credentials are that I'm a former power plant system engineer for secondary side systems, previous engineering inspector and currently working for a federal agency involved with nuclear power and over 25 years of experience in this area.
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
RE: convective flow
