Right Click Properties
MIS recently upgraded my operating system from Windows 2000 to XP. I use Autodesk Map 2005 on a network license; no settings were saved during the system upgrade. I can not right click to bring up menu with "PROPERTIES". The right click was fine until the upgrade. MIS is of no help on the matter, they are knowledge limited to installaion only. Other users are stumped by my problem and are concerned MIS may "fix" their computers soon.
Any suggestions?
MPENNENGR
RIDOT
Any suggestions?
MPENNENGR
RIDOT
RE: Right Click Properties
Scott
PICKFIRST is not the problem . . . attached is a bitmap of the right click menu that is brought up after selecting a line with the standard left click mouse.
It would appear that this should be controlled under "OPTIONS" "USER PREFERENCES Windows Standard Behavior" "RIGHT CLICK - CUSTOMIZATION". Is there some other locaton that has an influence on the SHORT CUT MENU.
MPENNENGR
RIDOT
Scott
PICKFIRST 0 gave me no menu when right clicking
PICKFIRST 1 gave me the limited menu when right clicking
I repeated these actions several times without a change in the results. PICKFIRST was not toggling the non/verb switch.
Then I manually enabled the noun/verb switch and PICKFIRST 0 and 1 once again worked as designed and toggled noun/verb. Am I missing something? Software glitch???
Should there be more problems I will follow atook's advise and request MIS reload AutoCad. (Other items of interest are my CD burner will not operate. MIS responded by loading deleting ROXIO and installing NERO 8 and ACROBAT 8; my CD burner stil does not work.)
MPENNENGR
RIDOT
