Code requirement for stop check valve on Brazil steam generator
IS there a Brazilian code requirement for the stop-check valve coming off a steam generator that requires the stop-check valve to have a drain on it?
RE: Code requirement for stop check valve on Brazil steam generator
I would check the requirements of NR-13. I don't have my copy handy but that is the best place to start.
