inserting workcell layouts
Is there a way to import a floor layout from autocad into solidworks, so that i could position the robots, and workcell in there world position. Once everything in its correct position I would be able to preform a basic reach study with robots that where flexable assemblys.
thanks for any help and advice
Matthew
RE: inserting workcell layouts
Copy the lines/arcs etc. in AutoCAD, then start a new sketch in SW and paste.
Rather than copy the complete floor plan, I'm not sure if you would want to copy the individual machines into it's own part and then start an assembly and insert the individual machines instead.
Another option would be to save the machines as a block in SW and re-use them as necessary.
Flores
You can insert DXF and DWG into a SW part, "Insert --> DXF/DWG".
I have used the insert per TheTick.
It may bog down your pc though.
Chris
SolidWorks/PDMWorks 08 2.0
AutoCAD 06/08
ctopher's home (updated 10-07-07)
