Hot Dip Galvanize 10.9 Threaded Stud Bolt
Hello, while researching Hot Dip Galavanizing, I came across this thread.
thread330-48335: Metal Embrittlement in galvanized bolts
It expressed concern about hydgrogen embrittlement.
We are seeking to have a 10.9 grade steel threaded stud (M36x560mm) hot dip galvanized at a bath temp of about 850F, to ASTM A153 spec. In ASTM A153, sect 5.3, it covers possible Hydrogen Embrittlement. This section refers to ASTM A143.
In A143, section 4.2 it references steel exceeding 150 ksi. We are using a class 10.9 steel with these physical properties BEFORE galvanizing.
Tensile KSI 157.0
Yeild KSI 150.0
% Elongation 33.2
Reduction of area 53.0
What might be the problems we encounter with the properties of the steel AFTER hot dip galvanizing?
Tensile KSI 157.0
Yeild KSI 150.0
% Elongation 33.2
RE: Hot Dip Galvanize 10.9 Threaded Stud Bolt
http://w
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
