Avoiding SMARTEAM checkout of unchanged parts
Hi all
I have serveral CATParts built from sketches imported from a "master" CATpart.
The structure is like this, although you have to think in complex structures with at least 100 sketches and around 50 parts. This is only a small sample.
Master_Part
|- Sketch 1 --(import w/link)--> Part_1
|- Sketch 2 --(import w/link)--> Part_2
If I change Sketch_1, only Part_1 will be affected. However, as Master_Part has changed, Smarteam forces to check out Part_1 and Part_2, even when Part_2 has not changed (CATIA won´t ask to update it anyway)
I would like to find a way to avoid unchanged parts being checked out, so tracking actually changed parts in complex designs is possible.
Any idea?
Master_Part
Any idea?
RE: Avoiding SMARTEAM checkout of unchanged parts
