wrong run direction on 3 phase pump motor
I connected a 3 phase motor of a centrifugal pump (0.75 kW)
After connection it turned the wrong way round.
My connection is the following
W2 ----- U2 ----- V2
U1 ----- V1 ----- W1
R S T
Which cables do I need to change in order to change the turning direction of the motor?
Do I have to switch R with S or T with S??
R S T
RE: wrong run direction on 3 phase pump motor
You can swap R with S or R with T or S with T.
Isn't important. In all cases you will have reverse rotate of motor. But important put labeles accordantly
Regards.
Slava
S R T
* Women are like the police. They can have all the evidence in the world and yet they still want a confession - Chris Rock *
On a three phase motor, if connected and it runs opposite of the direction you want it to turn just swap any two leads and it will turn the other way.
www.retallickeng.com.au
Was told it couldnt be done, so
i went and did it!
