Unable to open UG file
Greetings to all,
I have some UG version 18 files in my machine saved 2 years ago. Recently as similar project came up i tried to open the files in NX2, as 18 Version we no more use. I am getting a error saying "The following files could not be loaded causing this open to fail: C:\filepath\partname.prt - Not a part file"
I tried opening in NX4 it also throws the same error.
UG says its not a part file :(
Is there a solution to this or do i need to report to GTAC with the part file ?
Has any one came across this error.
Karthikj
Karthikj
RE: Unable to open UG file
Other than that, I'd say if the files are definitely UG files, you'll probably have to contact GTAC to get the files opened.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
Some people are like slinkies....they don't really have a purpose, but they still bring a smile to your face when you push them down the stairs.
If you used some kind of backup be it RAR or ZIP let us know, but I wonder if you haven't opened one of multiple volumes and that why your part file would be incomplete.
Good Luck
Hudson
Hi Hudson i tried with no components but no luck.
Thanks for the replies,
KarthikJ
Let us know how you go.
Best regards
Hudson
