Integration problem
Integration problem
I am try to solve a set of equations that has a rather nasty integration in volved. It is equation 4 in the attached file. When I invoke the quad function I get back the following error
Warning: Explicit integral could not be found.
Is there a method to get around this, how can I get matlab to solve the integral or is there another mathematical approach I could take. I tried using double in front of the int command but got a different error.
Matty B
Matty B
RE: Integration problem
TTFN
