Trouble in open. CATProduct. Help
Hello, I need your help to solve the following problem. I am working with P3 CATIA V5R12, and I sent a. CATProduct which can not open. The program informs me that the following error attached as data.
I appreciate your urgent assistance.
Greetings
RE: Trouble in open. CATProduct. Help
Do you knowq if the CATProduct and the CATPart are R12 (or lower) ?
If those file came from R13 or over then you need to install a new CATIA code of the same level or above...
Eric N.
Thanks for your help, the file CATProduct was conducted in the R15 and saved as such, which is why I was unable habrirlo in my version R12.
You command a greeting
