Moment of Inertia about a Defined Axis in Assembly?
Is there any way in an assembly to select the axis for the moment of inertia calculated and listed in Mass Properties??
RE: Moment of Inertia about a Defined Axis in Assembly?
If you create a coordinate system, you can calculate mass properties around a selected cocrdinate system.
batHonesty may be the best policy, but insanity is a better defense.bat
http://www.EsoxRepublic.com-SolidWorks API VB programming help
