Lateral Torsional Buckling of Angles
I am curious as to what fellow engineers use as presumptions regarding lateral support of angles in bending. I am looking into AISC 13 Chapter F, Section 10.2 on lateral torsional buckling of angles.
Specifically, I am looking at a continuous angle that spans between the ends of roof joists (@ 5' O.C.) where the facade back-up studs are directly attached to the angle. The deck would span parallel to the angle in this case but would be fastened to the angle with 2 sidelap fasteners per 36".
Is the angle laterally supported by the deck?
Do the sidelap fasteners provide enough resistance to consider the angle laterally braced?
Am I missing something entirely on the lateral torsional buckling?
Thanks in advance.
Thanks in advance.
RE: Lateral Torsional Buckling of Angles
